Carbon Dragon Builders
Webmaster Looking for information on Builders and Owners: Send to Steve Adkins - Email and address or email: This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. [Anyone have information on Bruce Sparrow?] Selling: Flying: |
Building: Alan Sayers ![]() Ya, Japan ![]() Michael Larson and Matt Ruddell Erik J. Brans Brian Davis Kevin Lane Hugo Lienhart Wayne Meier Jim Mills Johnathon Pitt Gytis Tamulaitis No Longer Builder: |
Kitplanes, January 2000, reports that 35 Carbon Dragon sailplanes are built. Below are listed 9 flying and 18 building. Don Santee in "The History of the Sailplane Homebuilders Association" reports 110 sets of drawings sold, 3 built and 2 flying. I am the holder of drawings set #248.
Builder | Changes and other notes | Started | First Flight | Location |
Ozzie Haynes This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
Link to huge photos submitted by Alan Sayers 1/2005: Waiting on the Uk weather for the first test flight. Final finished weight 159 pounds. 9/28/2003: Wing load tested the Dragon yesterday,Saturday. It passed at 3g 465 kilos approximately 1000lbs.The wings weighs 27 lbs each. Fuselage, seat and harness 50 lbs. One Flapperon weighs 9.5 lbs. Rudder, tailplane and elevator weighs 9 lbs. |
2000 | 2005 soon | U.K. |
This email address is being protected from spambots. You need JavaScript enabled to view it.">Stéphane Abbet This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
New Website: www.carbondragon.ch Stéphane has created a new website with the largest number of contruction and flying images of the Carbon Dragon. |
1995 | 2000 | Switzerland, in Geneva |
Daniel Indermühle
This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
Now flying! See 5 great photos at: http://www.sailplanehomebuilders.com/cd_indermuehle.htm. Daniel reports, "After four years of building, and of course at least one sleepless night, the first flight of my great love affair has been performed last sunday, december the 17. 2000, at the airport of interlaken, by towing behind a car. First "flight" was just about 5 meters above ground to make sure the plane does what I expected of it. Then followed two towings up to 200 meters ground. Thanks a lot to any body for all the help, whether it was support in building, technical advice, encouraging, or just doubts if this thing would ever fly! Well it does - an as far as I could find out in the short flights - it does quite well!!" Previous reports: Building stronger wing. Complete load test at 4G (with total weight plane + pilot 150 kg) two-piece door in place of one-piece. I have redesigned the wing and horizontal-stabilizer with CAD to produce with CNC. DXF-files are available. Move wheel back. Concerned about plans vs. amount of aileron deflection. |
December 17, 2000 | Burgdorf, Switzerland | |
Steve Arndt This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
update 1/14/2002 - Steve has racked up many hours flying two seasons at Wallaby Ranchin Florida for two seasons. More recently, Steve replied to my question about twin engines for the Carbon Dragon, "Yes, twin model airplane engines. I have them both in the shop. They weigh just 4.7 pounds each and each will generate 8-10 horsepower depending on prop efficiency. I think one would do but two should give an excellent climb rate. I'm redesigning the fuselage to accommodate them and a retractable landing gear."
Debuted at SHA Workshop in Elmira, New York in summer 1999. Extremely beautifully finished sailplane. The CD was not allowed to fly at the workshop due to county restrictions. For photos, visit: http://www.sailplanehomebuilders.com/arndt_news_posting.htm |
About three years ago | Summer 1999 | Concord New Hampshire |
Jim Maupin | Now owned by Gary OsobaThis email address is being protected from spambots. You need JavaScript enabled to view it."> , prolific writer, who has made notable flights in the Prototype built by the late Jim Maupin. Jim built this glider extremely light as a proof-of-concept. Goal was 100 pounds, actual was 145 pounds. Normally, no homebuilt is ever built as light as the designer's prototype. Note: a crescent wrench is "permanently" duct-taped to the tail to improve the CG. www.jcpress.com/JMaupinLtd/home.htm Please do not contact the Maupin ... they no longer sell plans |
- | prototype | Tehachapi, California .... now Wichita, Kansas |
Frank Smallman |
Plans holder #6. Kitplanes reports that Smallman used West Systems Epoxy. Bill Moyes is providing aerotows with the TUG for aerotow. Bill Moyes, 2-4 Taylor Street, Waverly 2024, NSW, Australia Phone: 02-3187 5114 Fax 02 387 4472 |
- | - | Glen Innes N.S.W. 2370, Australia |
Graham Betts | Changed incidence on H. Stab. Building parallel to the boom results in heavy nose down pitch. Also, Betts at 198 pounds, changed his seating position towards the rear which required extensions on the rudder pedals. SHA 12/97 | - | 2/1/96 autotow |
Australia |
Mark Dunstone |
Flight tested the Carbon Dragon at high speed for flutter, oscillations or instability. Noted that cutting carbon fibers damages saw blades. Controls are light, easy to thermal, plenty of stall warning, spoiler is effective, and large rudder is effective ... from Kitplanes, page 32 | - | - | PO Box 10492, Wellington, New Zealand |
Clyde Farquar | With Betts above in SHA 12/97 ... two CDs in one photo! Note: Two flying CDs in one photo! Graham Betts and Clyde Farquar, Australia [See photograph in the Sailplane Builder, December 1997, page 7] |
- | - | Australia |
Builder | Plans | Changes and other notes | Started | Location |
Alan Sayers This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
504? | 5/2004: I intend to start building within the next six to eight weeks. I am currently "building" a 3D model in CAD / modelling software as I figure it will save me some time in the long run. I have digitised the airfoils for every station and am checking the camber, thickness and reynolds numbers to get a better understanding of Irv Culvers approach. I also intend to run the airfoils through XFoil and to run the 3D wing / model through some fluid flow cfd software I have available.
Have received some great help so far ..... Ozzie Haynes, Doug Hoffman, Yasuhi in Japan, David Swanson kindly sending me details |
5/2004 | UK |
Ron Draper This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
#401 | Hi, I just bought a set of Carbon Dragon Plans #401 from Guy Farser . I already own a Woodstock glider. Do you Know of anyone that could help me get a copy of the builders manual for the Carbon Dragon . My plans arrived in the origanial tube that Guy recived them in but the tube was open on one end when they were delivered to me . Regardlees there was no builders manual inclosed . So now I have the plans and no builders manual . I don't know what to do about that yet . just try to find one . I will start building and cutting parts while I search for a copy of the builders manual . If you would like to add me as a builder please do . Ronald Draper 1359 Shell Rd . Goodlettsville Tn 37072 Plans # 401 building from Thank You Ron Draper |
#504 | Unfortunately I was a little too late to obtain plans from the Maupins, just missed out when I went to place my order. I intend to start building within the next six to eight weeks. I am currently "building" a 3D model in CAD / modelling software as I figure it will save me some time in the long run. I have digitised the airfoils for every station and am checking the camber, thickness and reynolds numbers to get a better understanding of Irv Culvers approach. I also intend to run the airfoils through XFoil and to run the 3D wing / model through some fluid flow cfd software I have available. |
4/2004 | Britain |
Yasushi Akahori This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
- | Many project photos at http://fledge.hp.infoseek.co.jp/ including carbon parts, tail feathers, carbon spar, spar box drawings. A must see website! First contact with Ya was 5/14/2002 Newest images (Feb 2005) demonstrate load testing. ![]() |
- | Nagoya Japan |
Bill Best 1776 S. Palo Verde #110 Tucson, AZ 85713 520-304-2984 |
Michael Larson This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. with Matt Ruddell |
- | I have started building and would love to coordinate in any way. Anything that will reduce the time time taken is welcome, so get in touch with me. I'll put up a website on my CD progress as soon as I hit 10% or so. I am building a single plane together with Matt Ruddell. Hopefully it won't take too long. |
5/2002 | ? |
Alejandro Ramirez-Pineiro This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. Contact: http://www.manque-aircraft.com/Webingles.htm |
- | http://www.manque-aircraft.com/ A very improved, modern Carbon Dragon-like glider being produced in Chili. Its name is MANQUE which means Condor in mapuchean. Note: for nearly 50 years, gliders have been built in Chile. See website, Aerodynamic Analysis of the Carbon Dragon Airfoils. Also, producing carbon seat pan for sale. [Ultralight_Soaring] Digest Number 300 Yesterday we made the RH wing spar of the Manque UL glider. Photos on website: |
2000 | Chile |
Erik J. Brans This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
- | Progress is slow for a variety of reasons including a new baby and moving. At the moment I am carving out a working space for my CD and will continue with the production of the wing and flaperon ribs. The empennage is finished. Because I am heavier than Maupin, I have chosen a slightly stronger carbon on advice of AMOCO, where I bought the carbon (Thornel T350/35, 12K, 309NT) and will build the wing in a way that the leading edge is in one line, that moves the pressure point forward just enough to compensate for my heavier weight. |
- | The Netherlands |
Kevin Lane This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
- | Kevin is currently 75% done with the empennage and will start the wings this winter. |
2000 | Portland, OR |
Brian Davis This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. | - | Has plans. Reviewing the plans in detail. [update] Brian has developed a Word version of the Carbon Dragon Builders Manual complete with drawings. See home page (right hand column in table). | 1999 | Edmonton, AB Canada |
Doug Hoffman This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. or This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
- | - | - | Oakland, Michigan |
This email address is being protected from spambots. You need JavaScript enabled to view it.">Wayne Meier This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
- | Working on tail. Plenty of Sitka Spruce on hand with lengths up to 24' that | 1999 | ? |
Hugo Lienhart | - | Much progress http://www.cloudbase.ch/carbon/hl.htm http://www.cloudbase.ch/carbon/old-pics.htm Cloud Base - email: This email address is being protected from spambots. You need JavaScript enabled to view it.">This email address is being protected from spambots. You need JavaScript enabled to view it. |
1993 | Switzerland, in Geneva |
Syd Hall | - | Building modified Carbon Dragon with 3-piece wing which uses carbon yarn wrapped around a tang bolt with Kevlar 969 reinforcement. Composite, shoulder wing, one-piece fuselage with rectangular cross-section pod. | - | - |
David Swanson |
- | Highly modified Carbon Dragon + Minisigma blended sailplane named FoulAir (Sailplane Builder 8/97 pages 5 and 8). Has slotted flaps for 2:1 increase in wing area. Stalls at 20 mph. SHA, 9/97 | - | - |
Jim Mills | - | See article, Sailplane Builder December 1997. Kevlar Pod 90 % complete. Boom finished. Tail surface ready for skinning. Tow hook made on his own mill (look at his name again!). Jim Mills had a wonderful exhibit of his Carbon Dragon parts at the Western SHA workshop at Tehachapi. | - | - |
Johnathon Pitt |
- | Written several excellent articles for Sailplane Builder. | aprox 1995 | - |
Gytis Tamulaitis |
- | Building a three piece wing based on Mitchell Wing construction techniques | - | - |
John McGriff |
- | - | - | TN |
Jeff Snyder |
- | Attended 1996 Easter SHA Workshop at Elmira | - | - |
Larry Weihs |
- | - | - | Palm Springs California |
Mark Crist This email address is being protected from spambots. You need JavaScript enabled to view it. |
Mark is in Iraq for a tour of duty. All building plans are on hold. Recently, Mark decided to build a Sandlin BUG. His CD Plans have been sold. Mark sold Carbon Dragon parts and plans. See: http://www.cpinternet.com/sadkins/for_sale.htm Tail pieces, wing ribs, carbon hinges are finished. Using H. F. Blanton's plywood kit. The wing mid-ribs were built on Mark's kitchen table. Presently building a "Bug" ultralight. |
Dassel Minnesota |
Steve Adkins (me, the webmaster) |
Built mockup of the front half of the pod. Cockpit space is on par with the K-21 if you add 1 inch in width at station 24.0 to reach 18 inches (I believe the original design was 16 inches and expanded to 17 inches before completing the prototype). Project on hold due to pilot weight. | 3/1998 | Twin Cities Minneapolis |
H. F. Blanton 707-451-3341 4785 Esquivel Road,Vacaville, CA 95688 |
Fred is no longer building the die-cut plywood kits for the Carbon Dragon. | - | Vacaville, CA |
